Notices
Rear end gearing with C6
Old 10/28/14, 06:28 PM
Walterdurbin's Avatar
What would be a good combo 3.55, 3.73, 4.10 gears behind a C6 auto in a 92 Fox Body .... Go to drag race car engine is a 351 stroke R to 436cu. Extreme cam 1/8 mi. And some 1/4 mi.?
Old 10/29/14, 10:29 AM
legacy Tms Member
HOSS429's Avatar
how tall of rear tire are you planning to use ? ..
Old 10/29/14, 02:28 PM
I plan on using 28" M/T slicks
Old 10/29/14, 03:58 PM
legacy Tms Member
HOSS429's Avatar
it`s been a longtime since i`ve been to the drag strip .. if i remember correctly your optimum gearing would allow you to reach the finish line at the same rpm you make your shifts at ..for 1/8 mile blasts i always liked a 4;56 gear in my 429 tbird .. i would shift from first to second at 5500 rpm .. the 2nd to drive at 5500 rpm and reach the finish line at a bit under 5500 ..i had a 28 inch tire as well ..i dont remember my ET or speeds .. you mite be able to tote that tall a gear even for a full 1/4 with a high reving small block ..
Ecostang
11/3/22 08:50 PM
oilmanlee
9/10/15 07:33 PM
chadh92
7/29/15 06:56 AM
Kev006
7/8/15 05:29 AM
Quick Reply: Rear end gearing with C6
